‎05-12-2020 06:59 AM
I've seen mixed answers across the board when this question is asked. Is it possible to add a workflow to a record producer? There is a field called "Workflow" in the record producer record. Is this used to attach a workflow to a record producer?
‎05-12-2020 09:09 AM
I see.
So to run a workflow, I would need to do it within the workflow properties by selecting the target table or selecting a target table and a condition to run it. I can't run it just by selecting a workflow in that "Workflow" field within the record producer, correct?
‎05-12-2020 08:56 AM
Hi Prateek,
So are you saying that the "Workflow" field is in the record producer form because the record producer table extends from the base catalog item table? How would I attach a workflow to a record producer?
‎05-12-2020 09:03 AM
So once the record producer is submitted, it creates a record on the target table.
Depending on the fields and your requirement attach a workflow to the target table.
Like in Workflow properties.
Table -- is -- target table and
state -- is -- active or draft
Please mark my response as correct and helpful if it helped solved your question.
-Thanks
I see.
‎05-12-2020 09:29 AM
Yes that is correct.
Please mark my response as correct answer and helpful if it helped solved your question.
-Best Regards
Prateek kumar
-Thanks
‎05-12-2020 09:53 AM
You marked your answer as correct. Can you mark mine instead.
-Thanks
