Is it possible to create multiple RITM from a list collector?
JLeong
'Hope everyone is safe and healthy.
Is it possible to create multiple requested items (sc_req_item) based on a list collector? For example, if I have 5 items listed from the list collector, it will also create 6 RITM. Like order guide but from a regular request form.
If so, please provide the steps to do it.
Thank you in advance.
Jocelyn
Hi Saurab,
Thanks for sharing your script. It gave me ideas and helped me with what I need to accomplish.
I was able to create a catalog item for each list collector from a record producer. Attached is the script.
I also used Flow Designer to automate the fulfillment.
//*** cancel creation of global record ***//
current.setAbortAction(true);
//*** Create Service Catalog Request (SR) ***//
var newReq = new GlideRecord('sc_request');
newReq.initialize();
newReq.opened_by = gs.getUserID();
newReq.due_date = gs.endOfThisWeek();
newReq.short_description = 'ServiceNow Group Access Request';
if (producer.sna_request_for_other == 'no') {
newReq.requested_for = gs.getUserID();
newReq.requested_for = producer.sna_request_is_for;
var newID = newReq.insert();
//*** Create Catalog Item Request for added groups***//
var addGrp = producer.sna_groups_to_add.toString().split(',');
var remGrp = producer.sna_groups_to_remove.toString().split(',');
if (addGrp != '')
createItem(addGrp, 'Add User to Group');
if (remGrp != '')
createItem(remGrp, 'Remove User from Group');
function createItem(grpArray, addRemove) {
for (var i = 0; i < grpArray.length; i++) {
var userGrp = new GlideRecord('sys_user_group');
userGrp.addQuery('sys_id', grpArray[i]);
userGrp.query();
if (userGrp.next()) {
gs.log('Return Group= ' + userGrp.name); // Get group name
var newSI = new GlideRecord('sc_req_item');
newSI.initialize();
newSI.request = newID;
newSI.cat_item = 'a639c9db1bf7cc107b86542f0a4bcb0d'; // ServiceNow Group Access Catalog item
newSI.short_description = addRemove + ' - ' + userGrp.name;
newSI.due_date = gs.endOfThisWeek();
var newSIid = newSI.insert();
//*** Get the variables to be filled out in the User Options of the SI ***//
var itemName = newSI.cat_item.name;
var itemVar = new GlideRecord('item_option_new');
itemVar.addQuery('cat_item.name', itemName);
itemVar.query();
var itemVarList = [];
while (itemVar.next()) {
itemVarList.push(itemVar.getUniqueValue('name'));
//*** Populate Options - sc_item_option ***//
for (var x = 0; x < itemVarList.length; x++) {
var itemOption = new GlideRecord('sc_item_option');
itemOption.initialize();
itemOption.order = x;
itemOption.item_option_new = itemVarList[x];
if (itemOption.item_option_new == 'f2390d9f1bf7cc107b86542f0a4bcb6a') { // User requesting:
itemOption.value = newReq.requested_for;
if ((addRemove == 'Add User to Group') && (itemOption.item_option_new == '72390d9f1bf7cc107b86542f0a4bcb75')) { // Group to add
itemOption.value = userGrp.sys_id;
if ((addRemove == 'Remove User from Group') && (itemOption.item_option_new == '7e390d9f1bf7cc107b86542f0a4bcb6f')) { // Group to remove
var optionSysID = itemOption.insert();
//*** Populate Variable Ownerships - sc_item_option_mtom ***//
var itemM2M = new GlideRecord('sc_item_option_mtom');
itemM2M.initialize();
itemM2M.request_item = newSIid; // Parent Item
itemM2M.sc_item_option = optionSysID; // Dependent Value
itemM2M.insert();
gs.addInfoMessage("Thank you! Your request has been submitted - " + newReq.number);
producer.redirect = "sc_request_list.do";
11 REPLIES 11
tsylte
Just wanted to say that I used this script in a Quebec environment and it worked great! Lots of possibility here for use cases where there's a gap in what Flow Designer can accomplish for you. Thanks for sharing!
Fred Jean
You could also use the Cart API for this  :
https://docs.servicenow.com/bundle/tokyo-application-development/page/app-store/dev_portal/API_reference/CartJSScoped/concept/c_CartJSScoped.html
