10-02-2025 10:40 PM
I want to make character length of a string field of at least 40 character . Is there any way configure it without scripting or we have to approach through script ?
Thank You
10-02-2025 10:58 PM
on string field in dictionary you can use max_length to allow max characters
but nothing OOTB is present for minimum length
you will require onChange client script for this.
10-03-2025 02:04 AM
Hi @1_DipikaD,
You can set the maximum character length in the Dictionary for that field. However, if you also want to ensure the field contains at least 40 characters, you’ll need to add an onChange client script on field to enforce that.
Please mark my response helpful and accept as solution
Thanks & Regards
Mayank
10-17-2025 02:31 AM
It will be like mixture of onChanage and onSubmit client script . But not sure if it is fine to pursue or not .
10-17-2025 04:12 AM
then either use onchange or onsubmit client script.
10-02-2025 11:05 PM
You cannot enforce a minimum length constraint declaratively (OOB) for a String field, you’ll need to use scripting (for example, a Client Script onChange or onSubmit) to check value.length and throw an error or prevent submission if it’s below 40 characters....
If you found my response helpful, please mark it as ‘Accept as Solution’ and ‘Helpful’. This helps other community members find the right answer more easily and supports the community.
10-03-2025 02:04 AM
Hi @1_DipikaD,
Thanks & Regards
Mayank
10-05-2025 09:55 PM - edited 10-24-2025 11:22 PM
Hi @1_DipikaD,
You can accept multiple responses as solution, if my response was helpful, mark it as helpful or accept it as solution
Thanks & Regards
Mayank
