Issue in calculating time difference in different timezone
kun1
Hi Team,
My system timezone is in EST and servicenow timezone is in  IST. Below are the script which calculate time difference but its not working properly.
Catalog Client Script:-
    if (isLoading)
    //start the validation for star date time.
    if (newValue != '')
        var ga = new GlideAjax('BIIB_CPGResizeConfirmDate');
        ga.addParam('sysparm_name', 'chkstartstopDate');
        ga.addParam('sysparm_time', g_form.getValue('planned_start_date_time'));
        ga.getXML(NewParse);
    function NewParse(response) {
        if (answer == 'false') {
            alert("Please select a future date");
            g_form.setValue('planned_start_date_time', '');
Script include:-
var BIIB_CPGResizeConfirmDate = Class.create();
BIIB_CPGResizeConfirmDate.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    chkCurrDate: function() {//Check if given Date time is in past or not.
        var ActualEndDate = this.getParameter('sysparm_time');
        var dif = gs.dateDiff(gs.nowDateTime(), ActualEndDate, true);
        if (dif < 1800) {
            return false;
            return true;
    chkstartstopDate: function() {//Check if given Date time is in past or not for start stop.
        if (dif < -2) {
            return false;
            return true;
it will not calculating time diff properly when system(EST) and servicenow (IST) timezone is diff
22 REPLIES 22
Mahendra RC
Hello Kun,
Please check with below at or before today condition once. Also if you want the validation to happen onLoad then check On load checkbox: Replace your field name in filter condition. Also if you want to allow today's date then change the filter to at or before Yesterday
function onCondition() {
	g_form.clearValue("start_date"); // replace your field name here
	g_form.showFieldMsg("start_date", "Please select future date", "error"); // replace your field name here
Please mark my respsone as helpful/correct, if it answer your question.
I also tried this but time will take in the variable in my system time but timezone is servicenow timezone.
Hello Kun,
Please check with below client script:
Client script on planned_start_date_time field:
    if (newValue) {
        var ga = new GlideAjax('CustomClientDateTimeUtils');
        ga.addParam('sysparm_name', 'compareToCurrentTime');
        ga.addParam('sysparm_selected_time', newValue);
        ga.getXMLAnswer(parseReceivedData);
	function parseReceivedData(answer) {
		alert(answer);
		if (answer == "false") {
			g_form.clearValue("planned_start_date_time");
			g_form.showFieldMsg("planned_start_date_time", "Please select future date", "error");
Script Include where Client callable is checked: Script will get the current time in user's timezone and compare with the date time selected by user as per his timezone:
var CustomClientDateTimeUtils = Class.create();
CustomClientDateTimeUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	compareToCurrentTime: function() {
		var selectedTime = this.getParameter("sysparm_selected_time");
		var selectedGDT = new GlideDateTime();
		selectedGDT.setDisplayValue(selectedTime);
		var selectedTimeInUserTZ = selectedGDT.getDisplayValue();
		var currentGDT = new GlideDateTime();
		var currentTimeInUserTZ = currentGDT.getDisplayValue();
		if (selectedTimeInUserTZ < currentTimeInUserTZ) {
			return false;
			return true;
    type: 'CustomClientDateTimeUtils'
Time taken in Variable on form is system time.
and below are the logs:-
Note- My system timezone is EST and servicenow is IST and it will take time in EST and time zone in IST
its not converting var selectedTimeInUserTZ = selectedGDT.getDisplayValue();
        gs.log("kunG3"+selectedTimeInUserTZ);
into user time zone as per logs
