Issue in g_scratchpad(Using on submit client script)
Venky Kshatriy2
Hi Team,
below mentioned code i am used to call the script include to on submit client script and setting value based on that restrict the user
front of the service portal it's working fine i am getting value and it's set  to variable but
If i used the in catalog item we have a TRYIT UI action if use this button and test click the order button  i am getting the bellow error
onSubmit script error: ReferenceError: g_scratchpad is not defined:
function () { [native code] }
function onSubmit() {
    if (g_scratchpad.validForm) {
    var reason1 = g_form.getValue('reason1');
    var reason2 = g_form.getValue('reason2');
    var mrvs = g_form.getValue('risk_rating_from_country');
    var vk = new GlideAjax("Decision_table_risk_rating");
    vk.addParam('sysparm_name', 'getriskratings');
    vk.addParam('sysparm_from', g_form.getValue('from'));
    vk.addParam('sysparam_to', g_form.getValue('to'));
    vk.addParam('sysparam_mrvs', mrvs);
    vk.getXML(function risk(response) {
        alert('risk rating' + answer);
        g_form.setValue('risk_rating', answer);
        if (answer == 1 && reason1 == '' && reason2 == '') {
            g_form.setVisible('reason1', true);
            g_form.setVisible('reason2', true);
            g_form.setMandatory('reason1', true);
            g_form.setMandatory('reason2', true);
            g_scratchpad.validForm = false;
            g_scratchpad.validForm = true;
            g_form.submit();
    return false;
Front of portal it's setting the variable value in below image
could pls help to resolve this error
Advance thanks.
-O-
As far as I know g_scratchpad is not supported in CMS - only in Portal.
A workaround could be "simulating" it, something like:
function onSubmit () {
	var scratchpad = getExistingScratchpad() || getCustomScratchpad();
	if (scratchpad.validForm) {
	vk.getXML(function risk (response) {
		else {
			g_form.submit();
	return false;
	function getCustomScratchpad () {
		return NOW.g_scratchpad = NOW.g_scratchpad || {};
	function getExistingScratchpad () {
		if (typeof g_scratchpad != 'undefined')
			return g_scratchpad;
11 REPLIES 11
Thanks for explain @-O-  it's really helpful to me
You're most welcome 🙂
