Issue with Adding/Removing Users from Group
chaitalivale
Hello Community,
I’m encountering an issue when trying to add or remove users from a group. I receive an info message, but even after waiting for a few minutes, the changes are not reflected in the group.
Could you please suggest a resolution for this issue?
Your help is truly appreciated!
Thanks!
9 REPLIES 9
Dr Atul - LNG
Hi @chaitalivale
It should work in the second action, actually. Whenever you change the bot, the reflection means the user is still part of the group — is that correct?
Bhuvan
Giga Patron
@chaitalivale
Refer below knowledge articles
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0636107
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1269366
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
@chaitalivale
You can also refer below thread
https://www.servicenow.com/community/itsm-forum/what-job-add-or-removes-role-s-from-user-s-of-group-...
Bhuvan
Ankur Bawiskar
@chaitalivale
that's expected. the addition/removal happens via backend scheduled job and not immediately if there are lot of records to process and involved system property "glide.ui.schedule_slushbucket_save_for_group_roles"
check below links
What job add or removes role(s) from user(s) of group and why has it been queued?
Unable to Add Users with HR Roles to Groups When glide.ui.schedule_slushbucket_save_for_group_roles ...
Adding / removing role to a group with high number of users does not add / remove role to all the us...
As a workaround
