Issue with Adding/Removing Users from Group
09-29-2025 02:59 AM
Hello Community,
I’m encountering an issue when trying to add or remove users from a group. I receive an info message, but even after waiting for a few minutes, the changes are not reflected in the group.
Could you please suggest a resolution for this issue?
Your help is truly appreciated!
Thanks!
09-29-2025 08:38 PM
Hope you are doing good.
09-30-2025 03:40 AM
Hello @Ankur Bawiskar,
I have tried the solution which you provided. But still it didn't work.
09-30-2025 03:48 AM
10-06-2025 03:03 AM
09-29-2025 06:25 AM
Hi @chaitalivale ,
may be below debugging might help you .
Troubleshooting Steps
1. Check the Event Queue
- Navigate to System Policy → Events → Event Queue
- Look for events like group.member.add or group.member.remove
- See if they are stuck, delayed, or failed
2. Check Scheduled Jobs
- Go to System Definition → Scheduled Jobs
- Look for jobs related to group membership processing
- Ensure they are running successfully
3. Review Business Rules or Flows
- There might be a custom Business Rule or Flow that handles group membership updates
- If it’s misconfigured or slow, it can delay updates
4. Check ACLs and Roles
- Ensure the user performing the action has the necessary roles (e.g., group_admin)
- ACLs might block the update from being committed even if queued
NOTE/SUGGESTION -
- Temporarily switch to synchronous processing for testing (if safe)
- Add logging to the script or flow handling group updates
- Monitor the event queue for stuck or failed events
- Contact your ServiceNow admin to check for system performance issues
Rithika.ch
