Issue with Scheduled Exports
Sathwik1
We had a scheduled Export export which used to export all the incident table data daily at 6.00 am
so I have unchecked "Appended Timestamp"  so every time new data will replace in the MID Server..
For first time export all the records, but from second time only new records need to export...so this I can do by taking records which are updated last 24hrs...but here my issue is for saturday and sundays records...because in those two days the end users will not take data from the mid server..
so can any one suggest some alternative for this?
@Sathwik
Yes if they don't pick it up then they will miss as the file doesn't have timestamp and it will get overridden.
So now you have 3 approaches here
1) Inform them to pick the files on Saturday and Sunday as that is by their requirement that they required daily files to be pushed for records updated in last 24hrs
OR
2) Append timestamp so that file doesn't get overridden
OR
3) Approach 3
a) Don't run your existing Scheduled Data Export on Saturday and Sunday using the Condition script
b) Create fresh Scheduled Data Export and make it run Daily; This would only run on Saturday.
Create fresh export Target for this and create Folder for Saturday Export and give that path
You can handle this via Condition Script.
c) Create fresh Scheduled Data Export and make it run Daily; This would only run on Sunday.
Create fresh export Target for this and create Folder for Sunday Export and give that path
Easiest approach is 1st or 2nd But check with your client and business team on this
29 REPLIES 29
@Ankur Bawiskar
Client will not accept for 1st approach..
we are using almost 10 tables so data will be more high...so I don't want to proceed with 2nd procedure..
so I will proceed with 3rd procedure...but can use please provide me script how to stop schedule export on Saturday and Sunday…
and for Saturday and Sunday I will proceed with what you have mentioned..
but here the issue is almost I am using 10 tables...
so I want to create 10 schedule exports for Saturday and 10 for sunday....so can you please suggest any other alternative?
Since every table is different and you want for saturday and sunday you need to create those many scheduled data export
1 each for each table for saturday and 1 for sunday
Script to allow to run only on weekdays
answer = checkCondition();
function checkCondition(){
var d = new Date();
var dayOfWeek = d.getDay();
// exclude weekends
if(dayOfWeek != 6 && dayOfWeek != 7){
return true;
return false;
Script to allow only for saturday
var d = new Date();
if(dayOfWeek == 6){
return true;
return false;
Script to allow only for Sunday
var d = new Date();
if(dayOfWeek == 7){
return true;
return false;
Thank you @Ankur Bawiskar
I will try with the above script..but I had a small query...
Where I am using separate schedule for saturday and sunday,..so I am having option to select Saturday and sunday..
Run : Weekly
Day : Saturday/Sunday so I can use that thing right? why again to write script for saturday and sunday?
@Sathwik
that's correct; then no need to script in condition field
For Saturday - Weekly and Select Saturday
For Sunday -  Weekly and Select Sunday
@Sathwik
Let me know if I have answered your question.
If so, please mark my response as correct & helpful so that this thread can be closed and others can be benefited by this.
