04-23-2020 02:23 AM
When User1 submits the catalog Request with Requested For as REQUser1, then in REQ and RITM form Requested For is getting changed to User1
But if i impersonate user to any other user say USER2, then its working fine. whatever was mentioned requested for on the catalog form its getting populated same in REQ and RITM form.
This is occurring for a particular user. Can anyone please help to understand why it is happening.
Ak
Service Catalog
04-23-2020 02:57 AM
Do note that post was only about sc_request. So you also need to add a query for your sc_cart.
An extract from that post:
Business Rule
Table: sc_req_item
Insert = true
When: Async
Condition:
current.request.requested_for != current.variables.requested_for
Script:
var grREQ = new GlideRecord('sc_request');
grREQ.get(current.getValue('request'));
grREQ.setValue('requested_for', current.variables.requested_for);
grREQ.update();
})(current, previous);
Works instantly.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
04-23-2020 02:25 AM
Did you try clearing cache using cache.do and check?
04-23-2020 02:33 AM
No, can u guide me where should i use cache.do
04-23-2020 02:53 AM
I just tried it now, but it didn't helped me
04-23-2020 02:27 AM
Hi there,
Can you share how/what you are trying with some screenshots? Did you also set something up for this or completely out-of-the-box?
Out-of-the-box there is a default value on the requested_for field on sc_request. This same field is shown on sc_req_item (out-of-the-box there is actually no requested for field on sc_req_item, it's dotwalked from the sc_request).
Kind regards,
Mark
