Issues with Select Box default value/mandatory attribute
craigzeleznick
I currently have a select box and for the default value I have it as "-- Please Select --" but I also need this field to be mandatory field. When testing the red asterisk is there but if the field is left blank and the person submits the form anyway it still allows them to submit without filling in the mandatory fields.
Can someone point me in the right direction on how to fix this issue?
Hey Craig,
you can add an onSubmit client script:
function onSubmit() {
  var v = g_form.getValue('select');//the name of your field
  if(v == '-- Please Select --') {
  alert('You must choose an option in the select field');
  return false;
NOTE -
In place of "--Please Select --" put the value of that choice.
17 REPLIES 17
No use this
var v = g_form.getValue('Name of that Question');
I have done this and it still does not make the user fill in the question. All it does is highlight the variable on the form for a half second then lets the user submit.
Thank you,
Craig Zeleznick
Remove the Asterisk Sign That means Remove MANDATORY then it will work.
Because you are making Mandatory through onSubmit Script.
