Making work notes mandatory if additional comments are empty and making additional comments mandatory if worknotes has some value.
Bhavna Chauhan
I just want:
If user has closed completed a catalog task VIA ServiceNow THEN they should be required to enter EITHER worknote or additional comments.
- If user provides additional comments then worknotes are not required
- If user provides worknotes then additional comments are not required.
Solution: I was thinking to do this by client script but additional comments and worknotes label are not visible there, so i decided to create the Client Scrpt, but it also doesnt work. Cn anyone help?
Bhavna Chauhan
I have tried another way, first i made both additional comments and work notes mandatory using UI policy,where condition is State is Close Complete.
Then I create two onChange client scripts separetely: one for Additional comments and one for work notes:
OnChange Client Script will looks like this where field will be Worknotes:
OnChange Client Script will looks like this where field will be Addtional Comments:
Hence, it worked. 🙂
Bhavna Chauhan
Hence, it worked. 🙂
