Moving from one state to other in problem management
pasupuleti loke
In a problem ticket if it is in assess state can it be directly moved to closed state.
Mohith Devatte
Tera Sage
No i dont think so. In OOB version state flow it has to go through Assess and then RCA and then fix the problem , then move to resolved and then closed.
However you can tweak the condition in the COMPLETE UI action saying that it should be visible on assess state also you can achieve this. If you want you need to customize this way
Please accept the solution if it answers your query
