MRVS How to iterate and check each row if a variable value is not empty
Ljone
Giga Contributor
I have an Onsubmit client script that should check if for each rows, 1 variable: 'member_replacement' is not empty and all rows are filled in. How to achieve this?
We are auto-populating the addtion of row  and users need to update each row variable:member_replacement
below is my current script but not working .  Thank you.
function onSubmit() {
var multiRowVariableSet = JSON.parse(g_form.getValue('group_creation_members')); //internal name mrvs
var numberOfRows = multiRowVariableSet.length;
for (var i = 0; i < multiRowVariableSet.length; i++) {
alert(numberOfRows);
if(multiRowVariableSet[i].member_replacement == ""){                //variable name
alert("With Value "+ multiRowVariableSet.member_replacement + " " + multiRowVariableSet.group_member_name);
else{
alert("Without Value "+ multiRowVariableSet.member_replacement + " " + multiRowVariableSet.group_member_name);
Ankur Bawiskar
@Ljone
So you want to check if both the variables are non-empty
if any row has both the variables as empty then stop form submission
update as below
var mrv = JSON.parse(g_form.getValue('group_creation_members')); // mrvs internal name
if (mrv.length >= 1){
alert(mrv);
var memberArrCount = 0;
var replacingArrCount = 0;
for (var i=0; i<mrv.length; i++){
if(mrv[i].member_replacement != '')
memberArrCount++;
if(mrv[i].group_member_who_are_you_replacing != '')
replacingArrCount++;
if(mrv.length != memberArrCount && mrv.length != replacingArrCount){
alert('empty column');
return false;
@Ljone
Great!  It looks like you marked your own response as the correct answer, which may be confusing to others that read this later.
Please mark my response as correct and helpful to close the question and also benefit future readers if my response helped.
