Multiple Row Variable Set showing Catalog Client Script SyntaxError: Unexpected end of JSON input and Empty JSON Value
Edwin Ng
I am trying to compute the total value of 1 of the column in the MRVS and displayed onto a variable in the record producer as shown below:
I have followed the guide from the below link but to now avail.
Not able to retrieve Multi Row variable set data using onSubmit client script - IT Service Managemen...
From the below catalog client script, I have encountered error due to the parsing of the g_formGetValues. I also found out that the result of console.log(g_form.getValue('billing_request_insert_details')) is returning empty values despite I have filled the relevant field in the MRSV.
MRSV in preview
Error in Console
Details of MRSV
I would appreciate if anyone could assist on my problem.
kartiksethi
Hi @Edwin Ng
You can follow my reply to a similar community thread:
Add the total cost in multirow variable set
This thread might give you the required solution. Please check and let me know if you still face the issue.
Please mark my answer as correct if this solves your issues!
If it helped you in any way then please mark helpful!
Thanks and regards,
Kartik
11 REPLIES 11
kartiksethi
Hi @Edwin Ng
Thanks and regards,
Kartik
Hi Kartik,
Your solution worked well tho I see don't understand what caused the error I encountered.
I would appreciate that you could share some references on how the client script in the widget works.
Thanks!
Br,
Edwin
