Need help on ATF
pawank2
We have one variable , it is not visible in portal. while submit the request , ritm and sc_task is generated.
when i open the  sc_task record, variable is visible and it is mandatoy.
so how can i achieve in ATF, I have used set variable value  but it is not working as expected. I am getting error -
g_form  is not defined.
I have created this step after open the existing record.
Pawan
13 REPLIES 13
Dr Atul - LNG
Hi @pawank2
In ATF, you can test a variable only when it is available in the catalog item.
Hi Atul,
We have variable in catalog item but it is visible on sc_task record.
Are you getting the error at the task level or at the item level?
And are you testing the variable at the item level?
HI Atul,
I have created a step - set variable value after open the existing record(sc_task).
I am getting this error.
