Need help on passing key value pairs in Rest Post method
divyalakshmi
I have a requirement where whenever a record is created in a particular table (eg incident), i should pass the ticket number and other fields in key value pair like below in rest.
  "incidentid": "INC00101",
  "properties": [
          "code": "summary",
          "value": "test incident"
"code":"description",
"value":"test desc"
I have configured the Rest Outbound and the outbound requires only two parameters "incidentid" and "properties".
here Properties should push all the filled field names and values. i have written a BR on this table to call the rest outbound and trying to pass summary and application name in key value pair
var property=[];
var json = new JSON();
var r = new sn_ws.RESTMessageV2(incidentRestMessage, 'post');
r.setStringParameter('incidentid', current.number);
//summary
if(current.short_description)
var summary={"code":"Summary","value":current.short_description.toString()};
property.push(summary);
//ApplicationCode
if(current.cmdb_ci)
var ci={"code":"ApplicationCode","value":current.cmdb_ci.getDisplayValue().toString()};
property.push(ci);
r.setStringParameter('properties',JSON.stringify(property));
var response = r.execute();
var responseBody = response.getBody();
var rBody = r.getRequestBody();
gs.log("rest call for "+current.number +"   "+rBody); If i try to log the request body to check if the input parameters are correct i get the below log
rest call for INC00101{"incidentid": "INC00101","properties":"[{"code":"Summary","value":"heloo"},{"code":"ApplicationCode","value":"Fire TOOL"}]"}.
i am not sure why this " comes in place of " ". can anyone help me on achieving this ?
Divya Lakshmi.
Gaurav Bajaj
Hi Divya,
Did you try setting parameter with
setStringParameterNoEscape('properties',JSON.stringify(property));
Gaurav
Replied to your new post as this one has been already answered.
Gaurav
