Need to create incident record from flow designer if output message is 400 to 499 or 4 series
mastan babu ko1
how to create the incident from flow designer based on actions output.
If status code is 400 we need to create the incident record.
Not only 400, A series of 4 ?
Please help
Ankit_Matta
Hi mastan,
Every action has a built in object in the flow action status . There is a int variable action code in the object . You can directly access it and according to your condition write an action in the flow . I have attached a screenshot for your reference.
If my response helped please mark it correct,
regards ,
Ankit
