Need to edit fields copied when using copy change
swnewton
Mega Guru
Geneva added the ability to copy a change request.   We need to edit the fields that are copied on the change and the related change tasks. Where do we go to do that?
billhayes
You can configure which fields you want to copy to the new change request via Change > Administration > Change Properties. On this page you will see a field called 'List of attributes' and here you can remove fields or add fields from the comma separated list.
The change properties worked great for the change fields...thanks!
Any idea how to do the change task fields?
Harish49
This helped !!
Configured "List of attributes" in Change properties. Thanks!!
