need to fetch task number from the email body
srinidhi
Hello All,
I need to fetch sctask number from the email body and I need to update the record.
please help me with the script.
example number: SCTASK1234567.
Thanks.
Musab Rasheed
Below is example of fetching number from Subject, you can replicate for body as well.
https://www.servicenow.com/community/service-management-forum/need-to-extract-incident-number-or-cha...
Musab
13 REPLIES 13
@srinidhi
are you sure your query is correct? and you are having record into stock room table
st.addQuery('name', status)
Thanks, got the issue. My query was fetching only sys_id. i used below syntax to get the field value.
 var statusReference = task.u_digilocker.getRefRecord(); // Get the referenced GlideRecord
    if (statusReference.isValid()) {
        var status = statusReference.name; // Access the 'name' field of the referenced record
        gs.info('namee: ' + status);
My initial link about fetching number from email body works for you so kindly accept the solution and close the thread.
Musab
@Musab Rasheed  Accepted the solution,
Thanks.
