need to make variable mandatory and visible for specific group
pritimayee
Can anyone please help me on the below requirement. Need to make one variable visible when the logged in user is member of specific group and need to make mandatory if the variable request type is assign or delete.
12 REPLIES 12
Allen Andreas
You'd need to utilize GlideAjax in client script to go and check their membership and if true AND the field has a value you're looking for, then set the field to mandatory true.
Hello Allen,
I have tried with script include and client script. But if answer is true and req=='Assign' it is not working. Can you please let me know where is the mistake.
function onLoad() {
    var req = g_form.getValue('request_type');
    var ga = new GlideAjax("sdmebers"); //name of script include
    ga.addParam("sysparm_name", "validdate zitk"); //name of function
    ga.getXMLAnswer(callBack); //name of call back function
    function callBack(answer) {
        if (answer == 'true' && req == 'Assign'){
            g_form.setVisible('request_opm_order_email', true);
            g_form.setMandatory('request_opm_order_email', true);
            g_form.setMandatory('request_opm_order_email',', false);
            g_form.setVisible('request_opm_order_email', false);
first type error g_form.setMandatory('request_opm_order_email',', false);
should be
g_form.setMandatory('request_opm_order_email', false);
if not works  try below it should be easy.
You can create display business rule and client script use below script. using g_scratchpad you can set mandatory.
Business rule:
    var grusr = new GlideRecord('sys_user_grmember');
    grusr.addQuery('group', 'group_sys_id'); //give group sysid here
    grusr.addQuery('user', gs.getUserID());
    grusr.query();
    if (grusr.hasNext()) {
        g_scratchpad.fieldmadatory = true;
})(current, previous);
Client Script:
function onLoad() {
    if (g_scratchpad.fieldmadatory == true &&req=='Assign') {//if it is choice check choice value
Pavankumar
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
Allen Andreas
