Need to Populate Short description and description RITM variables on newly opened Change Request
Indup
HI guys,
There are two variables on RITM, Short Description & Description. If we open the RITM, in the related lists there is Change Request tab. So once we go to that Change Request tab and click new, it will give 3 options Normal, Standard and Emergency. Whatever we select, the change request form gets open. Then in that Change form i want to populate Short Description and Description fields with the values of Short Description and Description of RITM variables. FOr that i have written a BR and its not working. Can someone correct my code plz
my BR:
Table: sc_req_item
after-->insert
Script:
var a = new GlideRecord('change_request');
a.initialize();
a.get(current.sys_id);
a.short_description = current.variables.short_description;
a.description = current.variables.description;
a.insert();
Indup
23 REPLIES 23
So, if i create a reference field (u_ritm) on Change Request, then i need to pass the RITM number to that field. So using BR i can do that right? And using the before insert BR, can i populate all the three? RITM, SD and Description?
And as i mentioned, can i do this once i click the New button of change request?
Indup
Once you create new Field on CHG u_ritm
Then you click New on CHG in the related list RITM field will be auto-populated
Now you just need to use before insert BR on change_request and fetch the field/variable values using this Reference field.
BR Condition: current.u_ritm != ''
Script:
    // Add your code here
current.short_description = current.u_ritm.short_description;
current.description = current.u_ritm.description;
// OR
current.short_description = current.u_ritm.variables.variable1;
current.description = current.u_ritm.variables.variable2;
})(current, previous);
Ankur,
I ordered a cat item and when i click New button for CHange Requests on RITM related lists, It is showing Standard, Normal, Emergency links. SO i clikced on Normal, then a new change form got opened but the RITM number is not populating in u_ritm field
Indup
Ideally it should take to new form and not interceptor
If this setup is in your personal instance and you are ok to share details url and some admin credentials then share here -> ankurb.snow@gmail.com
Sure Ankur
