Need to remove a user from specific group if users not logged in 3o days
varma2
Need to remove a user from specific group if users not logged in 3o days.
Ex : I have group called ( ITSM_Group ) in that group we have multiple users, If any user not logged in more than 30days we need to remove the user from the group.
Please suggest,
Thanks ALL,
You can try this as well for better optimization
var arr = [];
var gr = new GlideRecord("sys_user");
var gdt = new GlideDateTime();
gdt.addDays(-30);// User not logged in 30 days
gr.addQuery("last_login_time","<=",gdt);
gr.addActiveQuery();
while(gr.next()){
	arr.push(gr.getUniqueValue());
var grp = new GlideRecord("sys_user_grmember");
grp.addQuery("user", "IN", arr.toString());
grp.addQuery("group", "b85d44954a3623120004689b2d5dd60a");
grp.query();
grp.deleteMultiple();
9 REPLIES 9
Ankur Bawiskar
either use daily schedule job or flow designer with no script and make it run daily
Example using Flow Designer
Remember to save and activate the flow
Hi Ankur,
We dont use flow designer below script works but it allows to delete one record at a time, but we have multiple record to delelte.
gs.info("row------"+gr.getRowCount());
while(gr.next()){
var grp=new GlideRecord("sys_user_grmember");
grp.addQuery("user",gr.sys_id);
grp.query();
while(grp.next()){
if(grp.group=='b85d44954a3623120004689b2d5dd60a'){ // Your Group sys_id
gs.info("Group member rowcount---"+grp.user.name); // No of user not logged in 30 days
Please suggest,
update as this
while(gr.next()){
    grp.query();
    if(grp.next())
        grp.deleteRecord();
var arr = [];
while(gr.next()){
grp.query();
Hi Ankur,
What ever code your provided looks works, But with same requirement we need acheve  some other way, I have submit one more question  could you please look at this.
https://community.servicenow.com/community?id=community_question&sys_id=ea5b781d1b205150cd3b33bc1d4b...
Thanks a lot.
