Need to visible "Add" button in related list in problem form when state is closed
Asha Pathak
When state is new , it shows the Add button in related list
But when state is closed , it does not show the Add button on related list
Is there any way to show Add button in related list when state is closed
2 ACCEPTED SOLUTIONS
Hi @Asha Pathak I am using OR condition here so as long as the parent table is problem, the 1st condition (parent.sys_class_name == 'problem') will execute and will ignore the other condition (parent.active == true), for other tables the parent.active will be true. this way there is no impact for other tables and condition works as expected.
Does it work? If yes please accept the solution:)
Harish
HI @Asha Pathak after checking itseems OOB servicenow you cannot add a CI to the closed records, we would need to do a changes to the OOB script include AssociateCIToTask.
Modified script:
    script include: AssociateCIToTask
function to modify: _isValidTask
    _isValidTask: function(id) {
        var gr = new GlideRecord('task');
        //return gr.get(id) && gr.active; // need to remove gr.active here to add Ci
        gs.info("ID==>"+ gr.get(id));
        return gr.get(id);
After modifying the above function CI gets added to the closed records
Harish
26 REPLIES 26
Hi @Asha Pathak is it working now? If yes please accept my Solution if not let me know happy to assist
Harish
@Harish KM  If we remove  parent.active == true
Does any changes appear in other functionality
Hi @Asha Pathak this script include applies only for incident table I believe else you can place the condition like this
canShowAddButton: function(parent, current) {
        var field = gs.getProperty('com.snc.incident.link_to_task.' + parent.sys_class_name);
        if (parent.sys_class_name == 'incident') {
            return current.isValidField(field);
            return parent.active == true && current.isValidField(field);
Harish
@Harish KM What does it mean parent.active == true?
Hi @Asha Pathak this refers to parent.active == true? (incident table field active ), if true the add button will be visible, if active field is false on incident record add button will be hidden
Harish
