Notification is not getting triggered on problem task form
jack33
I have written a notification on problem task table when record inserted or updated.And added condition when problem.priority = critical or high notification should be triggered to 'ABC' group(in the group field selected one group)
Notification is not getting triggred but if i remove condition problem.priority = critical or high ,it is getting triggered.
Problem and problem task both are having critical priority
Thank you for help
Issue has been solved. I was taking wrong field to refer problem. Correct field is Parent on problem task which refer problem.
Added condition parent.priority is high/critical
Ankur Bawiskar
@jack33
are you sure the problem task for which you are testing has the Problem->Priority = Critical or High?
are you sure the problem task for which you are testing has Problem field populated?
If both the above are valid then it should work fine
are you sure the problem task for which you are testing has the Problem->Priority = Critical or High? >>Yes
are you sure the problem task for which you are testing has Problem field populated? >> Yes
Still not working
