Pass 3 arrays through Events using gs.eventQueue()
Kumar38
I have 3 arrays to pass to events . Is there a way to pass  more than 2 Parameters through gs.eventQueue()
Hi Shankar,
you can use array of json objects and pass that in single event parameter in event.parm2
use that in parsing in the email script
sample json should look like; sample email script
    "fieldLabel": "Short Description",
    "previousValue": "Test",
    "currentValue": "Testing 123"
    "fieldLabel": "Assigned To",
    "previousValue": "Abel Tuter",
    "currentValue": "David Loo"
parsing in email script
var str = '[{"fieldLabel":"Short Description","previousValue":"Test","currentValue":"Testing 123"},{"fieldLabel":"Assigned To","previousValue":"Abel Tuter","currentValue":"David Loo"}]';
var parser = JSON.parse(str);
for(var i=0;i<parser.length;i++){
template.print('Field ' + parser[i].fieldLabel + ' changed from ' + parser[i].previousValue + ' to ' + parser[i].currentValue);
Hi Shankar,
