Pass Order Guide Variables to Catalog Task Without Showing in in each Catalog item in Order Guide
jwagner
I've created a new hire order guide with the several variables I'd like to share across all included catalog items.
Common info I'd like to have on all catalog tasks: Supervisor/First Name/Last Name/Shift/Title/Department/EmployeeID
Catalog items: Build Computer/ Setup Phone/ Setup Email/ Create Access
There is no need for the user to see all those fields listed on each catalog item within the order guide, but I want to pass the variables to help the fulfiller.
and the following set of informaktion I'd like to carry over to each catalog item, but
Brent Sutton
Hi Ya,
Create the common variables in a variable set and include the variable set on the order guide and all catalog items that can be selected in the order guide. In the variable set you need to create an onload client script with UI Type set to "All" so it runs on both platform and Service Portal. Should look something like this:
function onLoad() {
	if (window === null) {
		// check if we are in an order guide using the g_service_catalog api for Service Portal and Mobile
		var isOrderGuide = g_service_catalog.isOrderGuide();
		if (isOrderGuide) {
			//call function to hide the fields on the catalog items if this is an order guide.
			hideVariables();
	else {
		var item = gel("current_item");
		var guide = gel("sysparm_guide");
		if (item != null && guide != null && item.value != guide.value) {
			hideVariables();
	function hideVariables(){
		g_form.setDisplay('your_var1',false);
		g_form.setMandatory('your_var2',false);
		g_form.setDisplay('your_var2',false);
On the order guide tick "Cascade variables" option which will copy the value of the data captured in the order guide down to the Service Catalogue items
That should now hide the variables, when displayed within an order guide. More information can be found about cascading variables at the following link - Cascade an order guide variable
Let me know how you get along.
Brent
P.S. If my suggestion helped then please mark as helpful and/or correct so other community members can benefit from this information.
12 REPLIES 12
Hi Bent,
I am not sure If am clear with my issue.
I have written the code as below
function onLoad() {
if (isOrderGuide) {
hideVariables();
else {
if (item != null && guide != null && item.value != guide.value && item.value!='372510b11ba3ab80b1ab0dc8cd4bcbdb') {
hideVariables();
g_form.setDisplay('name',false);
g_form.setDisplay('first_name',false);
g_form.setDisplay('middle_name',false);
g_form.setDisplay('last_name',false);
g_form.setDisplay('division',false);
g_form.setDisplay('country',false);
g_form.setDisplay('location',false);
g_form.setDisplay('manager',false);
g_form.setDisplay('title',false);
g_form.setDisplay('termination',false);
I have included the variable set in each catalog item and it is hidden now with this script when the catalog items are included in order guide.
But if i want to submit a single catalog item (not from the order guide), the variables are not getting hidden
I even want the variable set to be hidden if only single catalog item is used for submitting the request
You've added an additional test on the item value. I think this is causing the problem. Try the following;
if (item != null && guide != null && item.value != guide.value && (guide != null && item.value !='372510b11ba3ab80b1ab0dc8cd4bcbdb')) {
Letme know if it works for you.
Brent
jwagner
Brent,
The variable set is helping me greatly, but all the variable set fields are still appearing on the order guide in each catalog item tab. Is there anyway to get them to pass through without listing them on each catalog item?
Jeremy
jwagner
Brent,
This worked like a champ. I did however have to change:
to
var item = g_form.getControl('current_item');
var guide = g_form.getControl('sysparm_guide');
I check all "Applies" items. See screenshot. Can you see an reason this will cause an issue?
Hi Jeremy,
The script only needs to be applied to "Applies on a Catalog Item view". You don't need to apply it at RITM, Task or Target record. I haven't seen any errors on our Kingston instance relating to the use of gel?
The use of "gel" or "$" (DOM manipulation) is the only way (I am aware of) to extract the item and guide sys_id's on the platform interface side. We normally steer away from DOM manipulation as it is prone to breaking between upgrades. However, according to the London release ServiceNow docs, this is still the preferred method for the cascading variables use case - Hide cascaded variables
If anyone can give me an alternative then I'd love to know. I posted a question on the community about year ago as I was looking for an alternative to gel or $ then.
Glad you got it working.
Brent
