Placeholder for String field on the From
Maria31
Hello all,
Could you please advise how to add Placeholder (Example text) to the field on the form in ServiceNow? I need something similar to Example text added to Variables?
For example I want to add to Description field to Incident form the following Placeholder (Example text):
You could achieve this with an onLoad client script like the example I created here.
Create a onload client script
function
 onLoad() {
    var field = g_form.getElement("u_name");
    if (field) {
        field.setAttribute('placeholder', 'Enter your name');
        field.style.color = 'red';
This Answer might be helpful, It worked for me
Alok Ranjan Das
Hi Maria,
You could navigate to field dictionary and set the default value of the field so it will always populate until field value is not overridden by user.
Kindly mark my answer as Correct and Helpful based on the Impact.
