Populate Short Description on case level based on Topic details field of type "Select Box"
When i am creating a case via record producer, there is one field "Topic Details " of data type "Select Box" , I want to populate Short description on case level with the value entered in Topic Details.
How can i populate Short description(which is of type String) with the value entered in Topic Details(Which is of type "Select Box").
so you don't want the short description to populate with OOB logic.
then use before insert business rule on Case table and similar script
current.short_description = current.variables.variableName.getDisplayValue(); // give the variable name here
OR you can use after insert BR if the before insert doesn't work
current.setWorkflow(false);
current.update();
Hi Ankur ,
Thanks for your reply , I figured out that script include was stopping that from changing , i made few changes and it worked!!
Gaurav Tyagi
