Populate the catalog item Variable label and values in RITM description
Somujit1
Is there a way I can define in the Flow designer, to display the variable label and filled in values on the RITM Description field for the catalog item being requested
I created a RITM Update record action in the flow to update the Description where it gives me option to select values using data pill and also shows a script option.
I have written the below script which return the variable values as comma separated.
However I am not able return the variable label and display it in line break format
var ritmSysId = fd_data.trigger.ritm.sys_id;
var rec = new GlideRecord('sc_req_item');
rec.get(ritmSysId);
var variableValue= rec.variables.getElements();
return variableValue;
Any suggestions on how to get the Variable label display values and display in sequence
@Somujit1
Glad to know.
Yes you can but for that you need to enhance the script and check if the value is not false
something like this
var ritm = new GlideRecord('sc_req_item');
ritm.get(ritmSysId);
var arr = [];
var variables = ritm.variables.getElements();
for (var i=0;i<variables.length;i++) {
var question = variables[i].getQuestion();
var label = question.getLabel();
var value = question.getDisplayValue();
if(label != '' && value != '' && value != 'false'){
arr.push(label + " - " + value);
return arr.join('\n');
@Somujit1
Please mark my response as correct and close the thread.
Hi @Ankur Bawiskar  It is giving me below error
Somujit1
@Ankur Bawiskar , I have a Additional Info variable in my catalog item. Using the above script it is returning the defined variable labels and their values.
Is there a way I can modify the script to display the Additional Info variable to be displayed as 'Details - <value>' at the end of all other variable labels and their values in the RITM description field
Thanks in advance.
Somujit
@Somujit1
so you don't want the Label - {Value} format?
@Ankur Bawiskar  in the catalog item i have below variables -
1. Type of Request
2. Application Name
3. Requested Date
4. Provide more details related to your request
In the RITM description, it needs to display as below
Type of Request - <value>
Application Name - <value>
Requested Date - <value>
Details - <value> (instead of the actual variable label name for #4)
