05-23-2023 10:17 PM
Is there a way I can define in the Flow designer, to display the variable label and filled in values on the RITM Description field for the catalog item being requested
I created a RITM Update record action in the flow to update the Description where it gives me option to select values using data pill and also shows a script option.
I have written the below script which return the variable values as comma separated.
However I am not able return the variable label and display it in line break format
Request Management
Service Catalog
05-23-2023 11:17 PM
Glad to know.
Yes you can but for that you need to enhance the script and check if the value is not false
something like this
var ritmSysId = fd_data.trigger.ritm.sys_id;
var ritm = new GlideRecord('sc_req_item');
ritm.get(ritmSysId);
var arr = [];
var variables = ritm.variables.getElements();
for (var i=0;i<variables.length;i++) {
var question = variables[i].getQuestion();
var label = question.getLabel();
var value = question.getDisplayValue();
if(label != '' && value != '' && value != 'false'){
arr.push(label + " - " + value);
return arr.join('\n');
06-06-2023 10:36 PM
yes that's possible
just use if statement and when that variable is being iterated replace the label
