POST method in outbound REST message
Rj27
Mega Guru
Can we define HTTP query parameters of post method (defined in outbound REST message) using any script?
My doubt is- here in script I am setting the parameters but there is a possibility there might be no value passed for any one of them (suppose field 'memory').
In that case when no value is there for memory, entire field/key named 'memory' should not be there in the content Shared above. The case SHOULD NOT be like "memory":' '. Rather there should be no memory at all.
TIA,
-Ruchi
Vishal Khandve
Hi Ruchi,
 have you added the variable substitution as below
Vishal
Baala T
Mega Guru
Hi Ruchi,
We can use JSON and few related methods as below.
REST Message POST Method.
and the script should be as below
var sName = 'Bala_0007';
var sAge = '30';
var sSalary = '';
//Build JSON Object
var reqBody = {};
if (sName)
    reqBody['name'] = sName;
if (sSalary)
    reqBody['salary'] = sSalary;
if (sAge)
    reqBody['age'] = sAge;
try {
	//JSON to String
	var sReqBodyData = JSON.stringify(reqBody);
    var r = new sn_ws.RESTMessageV2('Dummy REST API', 'POST');
    r.setStringParameterNoEscape('messageBody', sReqBodyData);
    var response = r.execute();
    var responseBody = response.getBody();
    var httpStatus = response.getStatusCode();
    gs.print(JSON.parse(responseBody));
} catch (ex) {
    var message = ex.message;
    gs.print(message);
This code will adds the field name which has value and send the same.
Bala T
