Problem Management Reports that include task root cause codes
LuanneI
How are companies creating Problem Management Reports to include root cause codes from tasks?
miftikhar20
Hello @LuanneI,
You can achieve this by creating your report on the Problem Task [problem_task] table instead of the main Problem table. This way, you’ll have direct access to the Root Cause Code and other task-level fields.
Then, include the Problem (parent) details in the report by adding related fields from the Problem record, for example, Problem Number, Problem Statement, or Description.
Result:
This setup lets you view both the individual task data (like root cause codes) and the high-level problem context in one place.
 If my response helped, please mark it as the accepted solution so others can benefit as well.
Dr Atul - LNG
Hi @LuanneI
You can create a report on the PTask table and then dot-walk to the parent/problem record to get all the fields from the parent. This is the best way to do it.
