Problem of ACL
01-13-2026 02:53 AM
Please could you help me with this problem, on the table sc_req_item
I have this query filter : company.nameLIKElafa^sys_created_onBETWEENjavascript:gs.dateGenerate('2025-12-01','00:00:00')@javascript:gs.dateGenerate('2026-01-13','23:59:59')^cat_item.price>javascript:global.getCurrencyFilter('sc_cat_item','price', 'EUR;0').
However, i have a error message : Part of the query on sc_req_item has been ignored because of insufficient access for 'query_range' operation on sc_req_item.cat_item.price
I have verified my ACLs but I didn't figure out how to fixe it. Could you help me please ?
01-13-2026 03:11 AM
Hi @aymane ,
go to the ACLs and add this filter and see if you find any relevant ACLs and try disabling them
look for query_range ACLs sc_req_item.* or sc_req_item.cat_item or sc_cat_item.price or sc_cat_item.*
Please mark my answer as helpful/correct if it resolves your query.
Chaitanya
01-13-2026 03:20 AM
hey @aymane
This error occurs because ServiceNow enforces query ACLs separately from read ACLs.
Even if a user can read sc_cat_item.price, they may still not be allowed to use range operators (>, <, BETWEEN) on that field, especially when it is dot-walked from sc_req_item.
The error clearly indicates a missing query_range permission.
Option 1 : Add Query ACL on sc_cat_item.price
This is the cleanest and best solution.
Steps: Create a new ACL with the following values:
Type: Record
Table: sc_cat_item
Field: price
Operation: query_range
Set the same roles or conditions that already have read access to the price field
Save the ACL
This explicitly allows range filters (>, <, BETWEEN) on the price field and fixes the warning.
Option 2: Table-level query_range ACL
If you want to allow range filtering on multiple fields:
Table: sc_cat_item
Field: leave empty
Note:
This allows range queries on all fields of the table, so use only if acceptable from a security perspective.
Option 3: Avoid Dot-Walking
If ACL changes are not allowed
First query sc_cat_item and identify items matching the price condition
Then filter sc_req_item using:
cat_item IN <list of sys_ids>
If this response helps, please mark it as Accept as Solution and Helpful.
Doing so helps others in the community and encourages me to keep contributing.
Vaishali Singh
01-13-2026 03:42 AM
Since sc_req_item.cat_item is a reference field, create ACL on the dot-walked field:
Type: read
Field specification: cat_item.price
Requires role: [your_role]
Kindly Mark helpful if it makes sense.
Shailendra
01-13-2026 04:32 AM
approach from @Najmuddin Mohd and @Chaitanya ILCR should help you
01-13-2026 05:00 AM
hi @aymane ,
n the latest ServiceNow versions, a new query range ACL is created automatically for some tables. This ACL controls who can run queries using operators like >, <, or BETWEEN.
That’s why your filter is failing — you don’t have access for this query range check.
To fix it, open the ACLs for that table (for example, sc_cat_item.price) and review the query range rule.
You can also use “Debug Security Rules” or the Script Debugger to see which ACLs are being checked in the background when your query runs.
If you found my solution helpful, please mark it as Helpful or Accepted Solution...!
thanks,
tejas
Email: adhalraotejas1018@gmail.com
LinkedIn: https://www.linkedin.com/in/tejas1018
