problem
Bhujangi Gawal1
when raise a problem ticket ?explain the working of personas in problem management,?
Hi @Bhujangi Gawal1 ,
A problem is a cause of one or more incidents. Create a problem to identify the root cause of the incidents and try to prevent them from happening again.
Role required: itil, sn_problem_write, admin, problem_admin, problem_manager, or problem_coordinator
  • You can generate a problem record manually from the problem module.
  • You can generate a problem from an incident.
  • You can create a record producer to log problems from the service catalog.
  • You can also generate a problem from an email when an appropriate inbound email action is configured.
Procedure
  1. Create the problem with one of these options.
    Option Description
    From the Problem module Navigate to Problem > Create New.
    From an incident
    1. Open the incident.
    2. On the context menu, click Create Problem.
    Note: Use the property List of attributes (comma-separated) that will be copied from the incident to create a new problem (com.snc.problem.create_from_incident.attributes) to specify fields on the Incident form. The values of these fields are copied to the respective fields on the Problem form.
  2. On the Problem form, fill in the fields.
    Problem form
    Name Definition
    Number Read-only field. Unique number to identify the problem.
    First reported by Task that first identified this Problem.
    Category Group to which the problem belongs to such as software, hardware. After selecting the category, select the subcategory, if applicable.
    Service Business service that the problem applies to.
    If you select a business service as the configuration item and that business service is also listed as the configuration item in any other active task, the active tasks icon (
    ) appears. Click the icon to view the list of all the other active tasks that are affecting the business service.
    You can view the BSM map (dependency view) of the selected business service by clicking the dependency icon
    Service Offering Consists of one or more service commitments that uniquely define the level of service in terms of availability, scope, pricing, and packaging options. Service offering enables you to receive different features and their levels of performance for a given service.
    Configuration item Configuration item (CI) that the problem applies to. The CI class of the selected configuration item identifies the type of problem, for example, hardware, network, or database.
    State
    For existing customers, the available states are: Open, Pending Change, Known Error, and Closed or Resolved.
    For new customers from Madrid, the state management process is applied. This state field is a read-only field. The field value changes as the problem proceeds from one state to another state. The states available are: New, Assess, Root Cause Analysis, Fix in Progress, Resolved, and Closed.
    Resolution code
    Indicates whether the problem is resolved, a fix is applied, a duplicate is available, or the problem coordinator accepts the risk.
    Note: This field appears only for new customers from Madrid or a later release as it is part of the state management process.
    Duplicate of When Resolution code is Duplicate, the Duplicate of field is the reference to the Problem from which the current Problem is duplicated.
    Impact Effect that the problem has on business. Select the appropriate impact level (High, Medium, or Low).
    Urgency Extent to which the problem resolution can bear delay. Select the appropriate urgency level (High, Medium, or Low).
    Priority How quickly the service desk should address the problem (Critical, High, Moderate, Low, or Planning). The Priority field is read-only and is set according to the Impact and Urgency values entered.
    Assignment group The group who will work on the incident.
    The business rule Populate Assignment Group based on CI/SO populates the Assignment group field based on the support group available for the configuration item (CI) or the Service offering consecutively.
    Note: The business rule is triggered when an incident is created or updated and when the Assignment group and the Assigned to field is empty.
    If you want to override the default value, you need to create new properties and provide the field in the property value that must be used to populate the Assignment group field. Create the properties in the following order of preference:
    • com.snc.problem.ci_assignment_group.field_name: identifies which CI field populates the Assignment group field.
    • com.snc.problem.service_offering_assignment_group.field_name: identifies which service offering field populates the Assignment group field.
    If the Assignment group field is blank, the incident is automatically assigned to a group.
    Assigned to Specific problem coordinator that the problem is assigned to. If an assignment rule applies, the problem is automatically assigned to the appropriate user or group.
    Problem Statement Description of the problem that the problem-solving team addressing. When you update the problem statement and move to another field, the Related Search field displays knowledge articles. If you configure the problem properties, then the Related Search field displays other related information related to the problem statement.
    Description Detailed description of the problem.
    Related Search Result of a search.
    Note: If you want to search and link a known error article or knowledge article to the Problem, click Attach.
    Notes
    Work notes list Users who receive notification when work notes are added to the problem.
    Work notes Inscription about the work that you perform on the Problem.
    Analysis Information
    Workaround
    Method that you have used to overcome the Problem. Providing a workaround if useful for fast Incident resolution. It can be a way of dealing with a problem or making something work despite the problem not being resolved.
    If a workaround is available, the problem coordinator can click the Communicate Workaround action to notify the related Incidents.
    Cause notes Inscription on what had caused the problem.
    Resolution Information
    Resolved by
    Read-only field. Name of the user who resolved the issue.
    Resolved Read-only field. The date and time when the Problem is resolved.
    Fix notes
    Inscription on how you have fixed the problem. If a fix is available, the problem coordinator can click the Communicate Fix action to notify the related Incidents.
    Other Information
    Opened by Read-only field. Name of the user who opened the problem.
    Opened Read-only field. The date and time when the user opened the Problem.
    Confirmed by Read-only field. Name of the user who confirms that the problem is valid and needs a resolution.
    Confirmed Read-only field. The date and time when the user confirms that the Problem is valid and needs a resolution.
    Fix by Read-only field. Name of the user who started the fix.
    Fix Read-only field. The date and time when the user started the fix.
  3. Click Submit.
    The problem enters the New state. If you have filled the mandatory fields that are necessary to move a problem record to the Assess state, the problem record directly moves to the Assess state. If you want to add any additional field for the assess state, you must add the field at System UI > Form Sections. For more information, refer Add a field in the assess mandatory field dialog.
