Problems and Problem Tasks
Richard Thomas2
Hi all,
I was wondering whether this was possible - I'd like to be able see how many related problem tasks there to each problem (like the related incidents field in Problem) I've created a database view that links problem ID to problem task but the trouble with that is that it doesn't show which problems have no tasks attached.
Any help or advice on this is very welcome and appreciated as always!
Rich
Alikutty A
Tera Sage
You could query this from your report designer.
Select your Table as Problem And add a Related List condition that says Problem Task-> Problem is Greater Than or Equal to 0
Thanks!
Shweta KHAJAPUR
You can view related Problem Task in the related list of each problem. Please find below screenshot.
Alikutty A
Tera Sage
Thanks!
Hi Ali,
Thank you for that! I hadn't used the new report UI yet so that's really helpful!
Kind regards
Rich
For Problem management I created problem task . Approver is not triggered so can you plz help me. How to trigger Approver in Problem Task.
