Pros and Cons of using Managed Documents
rev3
Mega Expert
Our Service Now instances have been under a lot of customization. There is a need for us to document the changes specially for discovery. I am trying to understand the benefits and issues with "Managed Documents" application. Any experience on managed documents would be helpful.
Thank You
Reva
14 REPLIES 14
I can address your question regarding user and group permisisons. In order for you to add a user in User Permissions, that user must have the document_management_user role. If you have just added the plugin without demo data, no one will have this role and you will see no one in the list. Group Permissions has a very similar restriction, except it is that the group must have the document_management_user role attached to it (which therefore would mean all the users that are a part of the group have it too).
Here is what the Script Include that by default determines who you see verifies this:
You're always welcome to send me a message through this forum and we can exchange email addresses if you want a quicker/more detailed response. I am not an expert like some of the gurus here, but we have been using Managed Documents for quite awhile now.
PS: Tip #1 for Managed Documents: Remember the UI Actions in the header (context menu) are absolutely necessary because you need them for the approvers.
I expected a collaborative environment wherein   Reviewers are able to upload a revised copy if they couldn't Approve the revision but I'm not seeing this option.   Am I missing something?   What's the difference between a Reviewer and an Approver (apart from being able to set a sequence for Approvers)?
If my memory serves me correctly, you are correct. Reviewers would have to reject the document - they would not have the ability (out of the box) to upload a new revision from that record. In a way, I can see the logic. If a reviewer has changes, those should be a new revision. This is one of the reasons I feel that the ServiceNow implementation is not great for collaboration. In a way, you could end up with a dozen revisions before it even passes the Reviewers.
Out of the box, all Reviewers must approve to proceed so really the only difference is that a Reviewer is not in order. I guess I can see the point in this, it's a larger group of people that need to review it but you don't want a specific order in place to do the approvals. For us the Reviewers are more the users that deal with it on a daily basis, the Approvers are management. I'm not sure I have come across a functional different in ServiceNow other than what you mentioned - you order Approvers and their approvals, whereas all Reviewers can review and approve simultaneously. Again - that's out of the box. You can of course customize how you see fit.
ServiceNow can be customized however you see fit. But I'm not sure I can see a logical process off the top of my head that is any better because, in all fairness, if one reviewer wants to make a change then all the reviewers should review it again. Sure you could customize a bit and give them a "Reject and Upload Suggested Revision" UI Action to close down the revision, upload a new file, kick off the workflow. But at the heart of this you are still doing the exact same thing, just automating a couple small steps. If that helps your users, then by all means, a great customization.
For us we still want to have an individual that authors the document. We do not want Reviewers or anyone else modifying the document - the last thing we need is someone to use a different font, size, etc. - these are the little things we rely on the individual to maintain and protect and why we do not allow Reviewers to modify the document itself, only make suggestions.
Goran WitchDoc
Keep a eye on this thread as well. Pretty much the same: ServiceNow as a Document Management Solution
Michal_Ziemba
Any successful implementations which allow group collaboration on managed documents in SN?
I have seen the webinar where someone implemented the embedded window from SharePoint displaying documents in Service Now related to the specific item (it was made on the example of a contract in that webinar but it can be a project or CI or service as well). And I believe that collaboration is better in SharePoint, especially in Office 365 than in ServiceNow (you can work on a different type of documents online). Can you prove otherwise?
