Reference field variables
Jude8
I have two reference field variables . They both point to same table . Variable A has 10 records , variable B options should be displayed based on selected choice in the variable A .
Sumanth16
Mega Patron
Hi @Jude8 ,
Please refer to below thread:
https://www.servicenow.com/community/sysadmin-forum/show-specific-choices-based-on-another-field-cho...
Thanks & Regards,
Sumanth Meda
Jude8
I have tried it but didnt work. I have created 2 custom tables and  i have two ref variables in catalog item. variable A refers to Custom table A , Variable B refers to custom table B . Custom table B has a reference field with custom table A.
whenever variable A is selected , variable B should display choices based on var A. Can you help on this
vishakhayadav24
Hi @Jude8
please try the below code and make modifications to your requirement
you can pass this ref qual in second variable
javascript: new scriptincludeName().YourFunctionName(current.variables.variable_a);
Script include:
 YourFunctionName: function(service) {  // service is your first selected variable-a
        var filterStr = '';
        var gr = new GlideRecord("your_table");
        gr.addQuery('field', service);
        var pArray = [];
        while (gr.next()) {
            pArray.push(gr.fieldname.toString());
        filterStr = 'sys_idIN' + pArray.toString();
        return filterStr;
