Regarding Update Set Connection btn 2 instances
Gayathri5
I am trying to connect 2 PDI instances via update set for that first step is to create the update source so while creating it is throwing me an error saying password/uname issue.
I am attaching the screenshot,here in the username and password we do have to provide the uname and password of other instance correct? I am providing the right credentials but it is still throwing me an error?
Did any1 face this kind of situation?
yes since you want to be connected to target instance.
Credentials should be for that instance user.
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Gayathri5
Problem Resolved, i figured out i have to provide the other instance system admin credentials,but i was providing the login credentials of that instance instead of Admin Profile Credentials. Now connection is successful. I am able to move the changes from one instance to another successfully.
Gayathri
