Removing the default login prompt for all users - Multi-Provider SSO
wil421
Mega Contributor
Hey all,
Currently we are trying to get multi-provider SSO working for internal employees as well as customers. We have the customer portion working correctly, they simply use the link we provide to the CMS site which passes the correct authentication sysID and redirects them to our portal for authentication and then back to SN with a SAML token.
For internal employees we would like them to do the same. The only issue is that we are not using a CMS site, so if they go to instance.service-now.com they are brought to the SN login page. Its a requirement that they not have to login again, or click on "Use External Login", or a custom link we put on this landing page.
How can we modify the default landing page to automatically pass the correct sysID for authentication. I understand that after the first successful login SN will remember which certification method to use, but we need a method to make this happen the first time they access the system after turning on MPSSO.
Thank you!
wil421
Mega Contributor
For anyone who is curious, we found a solution by creating a UI Page with the title "welcome" (Welcome with a capital W didnt work for us). This page overrides the default welcome page.
Source: Redirect to a custom landing/login page
There is one unintentional side effect that we have discovered. side_door.do will now longer work if you override the default welcome page. Our solution to this was to make another side door using a public UI Page. I copied the jelly script from the default login page for the ESS site and it seems to work just fine.
nikeshnikky
Ihave same requierment like this, can you please help on this:
