Reports and Custom Charts
bhenson
Kilo Expert
Good morning all,
Still learning ServiceNow and making my first foray into Custom Charts.   I have 2 reports that separately display the data I want to combine into 1 custom chart.   Is there any way to use those 2 reports as my Data Generators or find the code that renders those reports to copy into my Data Generators when I create them?
Struggling with getting the code right to generate the data and hoping for a way to leverage what I have already created in SN to create something new and wonderful.   🙂
Thanks in advance for your assistance.
20 REPLIES 20
sangun,
Sorry for the late reply - have not been out in the community much.
Here are my scripts for a 3-line comparison chart.
Render Script:
// Script will generate a chart of incidents opened in the last 30 days
// vs. number of incidents opened 1 year ago.
// Get the sys_id values for the sys_report_summary table entries build by our generators
  var openID = summary_sets.get("Num Incidents per day - one year ago");
  var closedID = summary_sets.get("Num Incidents per day - last 30 days");
  var midID = summary_sets.get("Num Incidents per day - two years ago");
//   var backLogID = summary_sets.get("Incident Backlog");
  // Gets a utility class for dataset manipulation
  var cu = new ChartUtil();
  cu.setTable('incident');
  cu.setColors("#FFDEAD,#7FFF00");
  ////cu.setColumn('Sequence') ;
  // Get the dataset for the one year ago incidents
  var open = new ChartGenerator("line");
  open.setTable('incident');
  open.setSummaryID(openID);
  var ds = open.getDataset();
  var chart = open.getChart(ds);
// Get the dataset for the current 30 days incidents and combine with the one year ago incidents into
  // a multi series dataset
  var closed = new ChartGenerator("line");
  closed.setTable('incident');
  closed.setSummaryID(closedID);
  closedDS = cu.addEmptyValues(closed.getDataset(), ds);
  ds = cu.mergeDatasets(ds, "One Year Ago", closed.getDataset(), "Past 30 Days");
  ds = cu.changeDatasetLabel(ds, "Number of Incidents");
  // Get the chart for the multi series bar chart of open and closed incidents
  var chart = closed.getChart(ds);
var plot = chart.getPlot();
gs.log("plot = "+ plot);
axisD = plot.getDomainAxis();
axisD.setLabel("Date");
axisV = plot.getRangeAxis();
axisV.setLabel("Number of Incidents");
gs.log("axisD = " + axisD);
gs.log("axisV = " + axisV);
// Change the spacing
  closed.setNoMargins();
// Add a bar renderer to the chart for past 30 days incidents
////   var closed = new ChartGenerator("line");
////   closed.setSummaryID(closedID);
////   var closedDS = cu.addEmptyValues(closed.getDataset(), ds);
////   closedDS = cu.changeDatasetLabel(closedDS, "Past 30 days");
////   var renderer = closed.getChartGenerator().getLineRenderer(Packages.java.awt.Color.GREEN, 3.0, false, true, true);
////   open.addRenderer(renderer, closedDS, true, "Past 30 days");
// Adds a line renderer to the chart to show the incidents 2 years ago
var line = new ChartGenerator("line");
line.setSummaryID(midID);
// plot2 = line.getPlot();
var lineDS = cu.addEmptyValues(line.getDataset(), ds);
lineDS = cu.changeDatasetLabel(lineDS, "Two Years Ago");
var renderer = line.getChartGenerator().getLineRenderer(Packages.java.awt.Color.lightGray, 3.0, false, true, true);
closed.addRenderer(renderer, lineDS, true, "Two Years Ago");
axisV2 = plot.getRangeAxis(1);
gs.log("axisV2 = " + axisV2);
axisV2 = plot.setRangeAxis(1,axisV);
// return our chart
  answer = chart;
Data Generator #1
//To make my job easier, I put all the key components at the top as variables.   So I can copy this quickly and just change what I need.
var table = "incident";
var field = "sys_created_on"; // Date Field
var trend = "date";
var query = "sys_created_onRELATIVEGE@dayofweek@ago@760^sys_created_onRELATIVELT@dayofweek@ago@730^EQ^TRENDBYsys_...";
var g_sequence = 0;   // This will give me the value for the Sequence field in the Summary Set Line.
var id = createSummary(); // This will create the Summary Set record.
current.summary = id;
queryForSetLines(); // This will fill in the Summary Set record with individual lines
current.setWorkflow(false);
current.update();
// Here is the script that you will need to tailor for your needs.
// This one is pretty simple, I am just taking a query for last year's change records per month and getting the total number.
function queryForSetLines() {
    var table1 = new GlideAggregate(table);
    table1.addTrend(field, trend);
    table1.addAggregate('MIN', field);
    table1.addAggregate('COUNT');
    table1.addQuery(query);
    table1.setGroup(false);
    table1.query();
    // Add Lines to Summary Set from iterating through the GlideAggregate query
    while (table1.next()) {
  months = table1.getAggregate('MIN', field);
  days = table1.getAggregate('MIN',field);
  counts = table1.getAggregate('COUNT');
  dateParts = days.split('-');
  month = dateParts[1];
  day = dateParts[2].substring(0,2);
  monthday = month+day;
// Since the date stamp is in yyyy-MM-dd 00:00:00 format, I have to parse it out, I only want the Month.
  var sStamp = months.split(" ");
  var sDate = sStamp[0].split("-");
  months = sDate[1];
  gs.log(months+': ' + counts); // When you are done testing, comment this out. [I forgot on my code]
  createSummaryLine(monthday, counts); // In the end we take the X axis (months) with the Y axes (counts)
// Nothing should need edited except for the expiration date (and even that may not be necessary to edit)
// This creates the actual record for the summary set, filling in all the required criteria.
function createSummary() {
      var expires = new Date();
      expires.setDate(expires.getDate() + 7); // This will expire 7 days from now
      var expDate = (expires.getMonth()+1)+'/'+expires.getDate()+'/'+expires.getFullYear()+' '+expires.getHours()+':'+expires.getMinutes()+':'+expires.getSeconds();
      var s = new GlideRecord("sys_report_summary");
      s.title = current.name;
      s.field = field;
      s.table = table;
      s.expires = expDate;
      return s.insert();
// Nothing should need edited below, this just creates the individual Summary Set lines
function createSummaryLine(key, value) {
      var xx = new String(value);
      if (xx.startsWith("error"))
      xx = parseInt(value);
      if (isNaN(xx))
      var s = new GlideRecord("sys_report_summary_line");
      s.summary = id;
      s.sequence = g_sequence++;
      s.value = value;
      s.category = key;
      s.name = key;
      s.insert();
Data Generator #2
var trend = "date";
var query = "sys_created_onONLast 30 days@javascript:gs.daysAgoStart(30)@javascript:gs.daysAgoEnd(0)^EQ^TRENDBYsys_created_on,date";
current.update();
    table1.query();
  months = sDate[1];
      s.field = field;
      s.table = table;
      return s.insert();
      if (isNaN(xx))
      s.summary = id;
      s.value = value;
      s.category = key;
      s.name = key;
      s.insert();
Data Generator 3
var trend = "date";
var query = "sys_created_onRELATIVEGE@dayofweek@ago@395^sys_created_onRELATIVELT@dayofweek@ago@365^EQ^TRENDBYsys_...";
current.update();
    table1.query();
  months = sDate[1];
      s.field = field;
      s.table = table;
      return s.insert();
      if (isNaN(xx))
      s.summary = id;
      s.value = value;
      s.category = key;
      s.name = key;
      s.insert();
Hope that helps if you are still needing this functionality.
