Requested Item State is being stuck to Pending
PGhate
Requested Item state is being stuck to "Pending" by default. Can you please assist what could be possible issue.
Hi Suseela,
Yes I figured it out it was one of the UI policies driving this change.
Thank you for your response!!!.
Glad you figured out the problem and fixed the issue.
Is there more information I can help you with?
If it's been answered, please mark appropriate answer  as the correct and/or helpful one so people know this has been taken care of and thread will be closed.
Suseela P.
@PGhate ,
Just checking on this one.
If it's been answered, please mark my answer above as the correct one so people know this has been taken care and thread will be closed.
Suseela P.
Abhijeet Khandr
Giga Expert
Hello PGhate,
Please find the below article  and link, this will help you solve your problem
Symptoms
The RITM state field is stuck at pending approval
Release
Kingston
Cause
 The state field value is being set at "Set Values" activity
Resolution
The RITM's state field remains at "Pending-Approval" even after approving the approval record is because the state value is set using the "Set Values" workflow activity.
Since the workflow did not reach the set values activity where we set the value of the RITM's state field, the value did not change.
Please mark helpful and correct if this helped you
Abhijeet
