Restrict request submission if mandatory field is not filled in.
nisha2606
Kilo Expert
Hello Everyone,
I have a scenario in my order guide that when form is not loaded completely user directly clicks on submit button without filling the mandatory field and REQ is created but with no details.
So, can anyone suggest me how can I give an alert to the user that if he clicks on submit button without filling the mandatory field the REQ shouldn't be submitted.
Nisha
nisha2606
Kilo Expert
For this i used ng-if directive with submit button, which made submit button to become visible after the user selected option in mandatory field.
<button ng-if="!hasMandatory()" ng-disabled="submitted" name="submit" ng-click="triggerOnSubmit()" class="btn btn-primary">{{submitButtonMsg}}</button>
<span ng-if="submitting" style="padding-left:4px">${Submitting...}</span>
This solved my issue. 🙂
Thanks everyone for all your inputs.
Nisha
16 REPLIES 16
if the above code works fine then it won't show the submit button unless complete form/page loads
not sure on the greyed out option.
where we will use this code. do i need to create a new client script(onLoad)
Yes create an onLoad client script.
I am using this code in the onLoad client script on order guide form(sc_cat_item_guide) to make the Submit button invisible on form load but its not working can you pls help me here...
function onLoad() {
     document.getElementById('submit').style.display='none';
Hi Nisha,
Can you check it with this?
function onLoad(){
(document).ready(function()
$("#submit").show();
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
