Retrieving Record Numbers Instead of sys_ids in ATF
Khalid9030
In ATF, we have two Record Query steps with different conditions for the same table. These two record conditions are called in the Set Field Values step(PFA). When I call these two records, I am getting the sys_ids instead of the record numbers (PFA).
Could you please advise how to retrieve the record numbers instead of the sys_ids in ATF?
@Khalid9030
something like this
Step execution script:
(function executeStep(inputs, outputs, stepResult, timeout) {
    var recordSysId = inputs.u_sysid
    var gr = new GlideRecord("incident");
    gr.addQuery("sys_id", recordSysId);
    if (gr.next()) {
        outputs.u_number = gr.getDisplayValue();
        stepResult.setOutputMessage('Found the record');
        stepResult.setSuccess();
        stepResult.setOutputMessage('Record not found');
        stepResult.setFailed();
}(inputs, outputs, stepResult, timeout));
For my testing: I used these steps and it worked and gave me the number taking sysId as input
Output:
@Ankur Bawiskar
Can you do same thing using the Run Server side ?
@Khalid9030
No because that OOB step has pre-defined output variable and you cannot add a custom output variable to it
You can do using 'Run server side script' test step by using the script like below example.
gr.addEncodedQuery('short_description=test^description=test');
gr.query()
while(gr.next()){
    outputs.record_id = gr.number; //gives the Number present on the Incident as output
Unfortunately, you can't take the Output of the Record query test step as Input in the Run server side script. So, you need to add the query in the script for your table.
If my answer helped you in any way, please mark it as helpful or correct.
Chidanand Kalmani
