Ritm visibility using assignment group and parent group
jobin1
Hi All
Need to get the below 3 values in Query BR how it can be achieve?
1. How we can get the current logged in user assignment group and its parent group in query BR?
2.How all Ritm group and its parent group can be get from Query BR.
3. If 1 and 2 are same(both condition returns same value) then those Ritms should only visible to logged in user
    var childIds = "";
    var groups = new global.ArrayUtil().convertArray(gs.getUser().getMyGroups());
    groups = groups.toString();
	current.addEncodedQuery("assignment_group.parentIN"+groups+"^ORassignment_groupIN"+groups);
})(current, previous);
25 REPLIES 25
@Murthy Chintalapudi
Also I checked in logs when the parent group members is login in then only parent group is returning in script.
you have only to adjust your query :
instead of
 current.addQuery("assignment_group", "IN", a.toString());
put :
current.addEncodedQuery('sys_idIN'+a+'^ORparentIN'+a);
No. its not working even now child group members also not able to see.
I think some modification only required in murthy's code so that child group also return in script.
@Murthy Chintalapudi Any luck ?
Give me a moment checking
Murthy
of course you have to put this line of code in Murthy Chintalapudi's script,  he is now here, he will definitely help you .
