Scenario Based Question - ITSM
priyayadav8
Whenever an Incident's priority changes to P1, you want to notify the user and make attachments mandatory .How to achieve this?
Sarthak Kashyap
Hi @priyayadav8 ,
I tried your problem in my PDI and it works for me please create OnBefore Business Rule on your Incident table, and add below script
    // Add your code here
    gs.log("Inside BR");
    if (current.priority == 1 || current.priority == "1") {
        if (current.hasAttachments() != true) {
            gs.log("Inside BR IF");
            gs.addErrorMessage("Please add an attachment");
            current.setAbortAction(true);
    gs.eventQueue('Event_Name', current, current.caller_id, current.assigned_to);
})(current, previous);
You can create a event from event Registry and create a Notification, trigger that notification when event is fired, and in who will receive section check the checkbox of recipient contains parm1 &parm2. Add your subject and body accordingly.
Result
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
Yes It's working
