Script Include response to filter reference field values/options.
CuriousMind
Kilo Explorer
Requirement:
I am trying to make an onChange script call a script include which queries the group member table for the group members of a particular group(field on the form). That script include sends back a list of users for a user table reference field on the form. I want the user field to have only this list of users available for selection.
 Issue:
The response which I get from the Script include simply gets pasted in the text area of the reference field. How do I make the User table reference field options filtered to the list of user received in response.
ScreentShot:
Script Include:
var MyScript = Class.create();
MyScript.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	MyFunction: function(group){
		var userList = [];
		var grpValue = this.getParameter('sysparm_gname');
		gs.log('1');
		var grp = new GlideRecord('sys_user_grmember');
		gs.log('2');
		grp.addQuery('group',grpValue);
		gs.log('3');
		grp.query();
		gs.log('4');
	/*	var grp = new GlideRecord('sys_user_grmember');
		grp.addQuery('group',group);
		grp.query();*/
		while(grp.next()) {
			//anArray.length == 0
/*			if (userList.length != 0) {
				userList += (',' + grp.user);gs.log('Loop1');
			else {
				userList = grp.user;gs.log('Loop2');
//		userList.push(grp.user.toString());
		userList.push(grp.getDisplayValue('user'));
		gs.log('Loop');
		gs.log('@@@Test:::: ' + userList);
		return userList.join();
		//return 'sys_idIN' +userList.join();
//		return '' + userList;
	type: 'MyScript'
Client Script:
	if (isLoading || newValue== '') {
		//Make server call
	g_form.setValue('grp_mmbr_ref', '');
		return ;
	if (newValue != oldValue) {
		//Make server call
		var ga = new GlideAjax('MyScript');//this is the script include
		ga.addParam('sysparm_name','MyFunction'); //this is the function within the script include
		ga.addParam('sysparm_gname', g_form.getValue('test_item_grp_ref'));
		ga.getXML(getResponse);
	function getResponse(response) {
	var values = response.responseXML.documentElement.getAttribute('answer').toString().split(',');//.split('|');
	g_form.setValue('grp_mmbr_ref', values);
		/*g_form.setValue('description', values[1]);*/
You can make the script include reusable on other fields. You simply pass it a group and it can return the members.
Your reference qualifier would be something like:
javascript:new myFilters().myGroupMembers(group_id);
The script include (called myFilters()) would have a function called myGroupMembers() that simply takes a group sys_id and looks through the sys_user_grmember table for all records with that group ID and returns a comma separated list of user IDs that go with it.
Example:
myGroupMembers : function(group_id) {
  var list = [];
  var mem = new GlideRecord('sys_user_grmember');
  mem.addQuery('group', group_id);
  mem.query();
  while (mem.next()) {
    list.push(mem.getValue('user'));
  return 'sys_idIN' + list.join(',');
11 REPLIES 11
That field is not on available service catalog items.
Oh Sorry My Mistake.
Let me check a code.
Ashutosh
Dependencies aren't available on catalog variables. 😞
Yeah my mistake. I didnt read it properly.
Ashutosh
Example:
  var list = [];
  mem.query();
