Script Include response to filter reference field values/options.
CuriousMind
Kilo Explorer
Requirement:
I am trying to make an onChange script call a script include which queries the group member table for the group members of a particular group(field on the form). That script include sends back a list of users for a user table reference field on the form. I want the user field to have only this list of users available for selection.
 Issue:
The response which I get from the Script include simply gets pasted in the text area of the reference field. How do I make the User table reference field options filtered to the list of user received in response.
ScreentShot:
Script Include:
var MyScript = Class.create();
MyScript.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	MyFunction: function(group){
		var userList = [];
		var grpValue = this.getParameter('sysparm_gname');
		gs.log('1');
		var grp = new GlideRecord('sys_user_grmember');
		gs.log('2');
		grp.addQuery('group',grpValue);
		gs.log('3');
		grp.query();
		gs.log('4');
	/*	var grp = new GlideRecord('sys_user_grmember');
		grp.addQuery('group',group);
		grp.query();*/
		while(grp.next()) {
			//anArray.length == 0
/*			if (userList.length != 0) {
				userList += (',' + grp.user);gs.log('Loop1');
			else {
				userList = grp.user;gs.log('Loop2');
//		userList.push(grp.user.toString());
		userList.push(grp.getDisplayValue('user'));
		gs.log('Loop');
		gs.log('@@@Test:::: ' + userList);
		return userList.join();
		//return 'sys_idIN' +userList.join();
//		return '' + userList;
	type: 'MyScript'
Client Script:
	if (isLoading || newValue== '') {
		//Make server call
	g_form.setValue('grp_mmbr_ref', '');
		return ;
	if (newValue != oldValue) {
		//Make server call
		var ga = new GlideAjax('MyScript');//this is the script include
		ga.addParam('sysparm_name','MyFunction'); //this is the function within the script include
		ga.addParam('sysparm_gname', g_form.getValue('test_item_grp_ref'));
		ga.getXML(getResponse);
	function getResponse(response) {
	var values = response.responseXML.documentElement.getAttribute('answer').toString().split(',');//.split('|');
	g_form.setValue('grp_mmbr_ref', values);
		/*g_form.setValue('description', values[1]);*/
You can make the script include reusable on other fields. You simply pass it a group and it can return the members.
Your reference qualifier would be something like:
javascript:new myFilters().myGroupMembers(group_id);
The script include (called myFilters()) would have a function called myGroupMembers() that simply takes a group sys_id and looks through the sys_user_grmember table for all records with that group ID and returns a comma separated list of user IDs that go with it.
Example:
myGroupMembers : function(group_id) {
  var list = [];
  var mem = new GlideRecord('sys_user_grmember');
  mem.addQuery('group', group_id);
  mem.query();
  while (mem.next()) {
    list.push(mem.getValue('user'));
  return 'sys_idIN' + list.join(',');
11 REPLIES 11
Great Chuck.
I tried something similar to that. It works now.
Hey why don't we have Dependent field for Catalog items.
Not criticizing but  trying to understand the technical reasoning or thought behind it.
I don't have an answer. You might want to reach out to customer support and ask. They may be able to find an answer or at least register that a customer is looking for this functionality.
