script not working from BR/workflow
Abdul Musavvir
I'm trying to generate a dynamic excel attachment from script. It is working perfectly fine but not from BR/workflow.
And also I'm getting all the logs with perfect value. Please suggest how to make it work from BR n workflow.
var selected_inc = "INC0000029,INC0000028,INC0000024,INC0000055";
var query = "incident_list.do?EXCEL&sysparm_query=numberIN"+selected_inc;
var instance_name = gs.getProperty('instance_name');
gs.print("query abdul" + instance_name +" " + query);
var sys_id ="b088ecfc2f3b3510c4fcfe1df699b69f";
try {
   var request = new sn_ws.RESTMessageV2();
   var instanceUrl = "https://"+instance_name+".service-now.com/";
	gs.print('url abdul'+instanceUrl + query);
   request.setEndpoint(instanceUrl + query);
   request.setHttpMethod("GET");
   var user = "admin";
   var password = "ABCD";
   request.setBasicAuth(user, password);
   //request.setRequestHeader("Accept", "application/json");
   gs.print("before resonse abdul");
request.saveResponseBodyAsAttachment("sc_req_item",sys_id,'resolved_incidents.xls');
	gs.print("after resonse abdul ");
   var response = request.execute();
   var httpStatus = response.getStatusCode();
   gs.print(httpStatus);
} catch (ex) {
      var message = ex.getMessage();
      gs.print(message);
-Abdul Musavvir
@Abdul Musavvir
when should this be generated?
what's the error you are getting?
@Ankur Bawiskar It is not throwing any error. Script is executing perfectly and I'm receiving all logs with correct values.
The attachment must be attached once the RITM is closed.
