Sending fax using flow designer.
User_267
How to send a fax using flow designer in servicenow.
Peter Bodelier
Hi @User_267,
You will need some kind of provider which can send a fax by leveraging a REST API. For example Fax REST API for Developers - Fax.to
Then you can create a Flow Action to use that API.
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
