Service Catalog Trigger does not work in Flow Designer
Haruka Kubota1
In my flow designer, I created a workflow where when a catalog item [sc_cat_item] is requested, an approver is assigned to RITM and a task [sc_task] is created.
But, Service Catalog Trigger does not work in Flow Designer.
When I checked Process Automation > Flow Administration > Today's Exections ,
there was no record of the history of the workflow running, so I guess the trigger is not running.
When I test the workflow in the flow designer, it works fine.
I'm having a very hard time getting the flow designer to work, so I hope someone can help me.
Your flow is configured to run as which user? System User?
also refer this link which talks about some workaround for BR on RITM table
Flow not triggered by Service Catalog
16 REPLIES 16
Ankur Bawiskar
@Haruka Kubota
Did you see any error in the flow while you saved or activated it?
please share the flow screenshot
vikas shukla
Can you share the screenshot of Flow and process engine.
Vikas
@vikas shukla
Thank you for your replay.
【catalog item】
【flow properties】
【flow designer】
Please let me know if there are any setting screens that are missing.
Haruka Kubota
Did you assign this activated flow to that catalog item?
Please provide the screenshot of process engine tab.
Vikas
